Dzwoniłeś już o to auto?
[O2] Pomoc w rozkodowaniu błędów. O2 przed fl. 2.0 TDI
Witam proszęo pomoc w diagnozie błędów. Dzięki.
Tuesday,28,April,2015,10:14:23:17642
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0
Data version: 20141022
Workshop Code: 048 33074 012345
VIN: TMBCE21Z458039271 License Plate:
Mileage: 76407mi Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 76 7D
VIN: TMBCE21Z458039271 Mileage: 283900km-176407miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HF HW: 028 101 229 2
Component: R4 2,0L EDC 0000SG 7000
Revision: 12345678 Serial number: SKZ7Z0E2968670
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 6ED31EEA79D3EF518D7-803B
4 Faults Found:
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High
Freeze Frame:
RPM: 819 /min
Torque: 30.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 11000000
Temperature: 56.7°C
Temperature: 52.2°C
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 252.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00000000
Temperature: -6.3°C
Bin. Bits: 00110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 252.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00000000
Temperature: -6.3°C
Bin. Bits: 00110000
16486 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
Freeze Frame:
RPM: 1050 /min
Torque: 6.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 80.5 %
Bin. Bits: 11000100
Mass Air / Rev.: 675.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 73430 790 00000
VCID: 3F8D93AE6E3956D9561-806A
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3B75E7BE7A214AF97A9-806E
1 Fault Found:
01273 - Fresh Air Blower (V2)
008 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000003036786
Coding: 018A0F120004140000110D000000000000087F065C
VCID: 3A7BE2BA751B73F161F-806F
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 120308 022 0601
Coding: 00055223
Shop #: WSC 73430
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit - Intermittent
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 L HW: 1K0 909 605 L
Component: Q2 AIRBAG VW8 025 0700
Revision: 08025000 Serial number: 0038CD07H3XA
Coding: 0020786
VCID: 3561F1865C059C898CD-8060
Subsystem 1 - Serial number: 6332MSME75167F10
Subsystem 2 - Serial number: 6342MSME1A250C09
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000012
Shop #: WSC 73430 790 00088
2 Faults Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 810 D
Component: KOMBIINSTRUMENT VD1 3562
Coding: 0007101
Shop #: WSC 00999 444 64523
VCID: 3365CF9E527182B9A29-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001054088651
Coding: 7D3F0F40071302
VCID: 29592DF680BDC869185-807C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3562
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0165
Coding: 0000116
VCID: 74E70C8217FFC5817B3-8021
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 B
Component: EPS_ZFLS Kl.2 1502
VCID: 2A5BD2FA85BBC37111F-807F
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00D002007F2D8505484F861004C8
VCID: 79F93DB6309DB8E9285-802C
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 7 - Component: NGS n.mounted
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
00668 - Supply Voltage Terminal 30
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000116
VCID: 75E131861C85DC894CD-8020
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0002
Coding: 0000007
1 Fault Found:
00070 - Starting Battery Voltage
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 A HW: 1Z0 035 161 A
Component: Radio FO3 011 3020
Revision: 00011000 Serial number: SKZ7Z3E0002470
Coding: 0000200
Shop #: WSC 00084 048 15860
VCID: 2C57D4E28F4FDD41E33-8079
1 Fault Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0219
Coding: 0000048
VCID: 2F6DC3EEBE59A659C61-807A
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 306FC092A367B9A1DFB-8065
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
VCID: 3D71E9A6643544C944D-8068
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 177
Mileage: 283750 km
Time Indication: 0
Date: 2000.00.00
Time: 17:35:15
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51D9E6B455D449F4D-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 02:05)-----------------
